Symbol Geometric Characteristic Description Typical Use Case Integration in CAD Inspection Notes
Flatness Ensures a surface is uniformly flat within the specified tolerance. Critical for sealing surfaces or bearing fits. Applied using surface tools for flatness analysis. Checked with a surface plate and gauge.
Perpendicularity Ensures a surface or feature is at 90° to a datum. Used for aligning holes or surfaces in assemblies. Ensures perpendicularity through datum alignment in CAD. Measured with a square or CMM.
// Parallelism Ensures a surface or feature is parallel to a datum. Ensures parallel alignment of mating surfaces. Checked by setting parallel planes in CAD models. Checked with a surface plate and gauge blocks.
Circularity Ensures all points on a circular feature are equidistant from the center. Applied to shafts, bores, or cylindrical parts. Analyzed using roundness measurement tools in CAD. Checked with a roundness measuring tool.
Cylindricity Ensures a feature is both round and straight along its length. Important for shafts and cylindrical components. Modeled with precise cylindrical constraints. Checked with a roundness/cylindricity gauge.
Profile of a Line Controls the contour of a line element in a cross-section. Used for controlling the profile of gears or blades. Designed using line profiling and cross-sectional tools. Measured using an optical comparator or profilometer.
~⌒~ Profile of a Surface Controls the shape, size, and form of a surface. Used for aerodynamic or freeform surfaces. Generated with surface profiling features in CAD. Measured using a profilometer or CMM.
Ø⏤ Position Specifies the allowable deviation of a feature’s location. Used for hole placements and ensuring assembly alignment. Defined using positional constraints in CAD software. Inspected using a CMM or optical comparator.
Concentricity Ensures features share the same axis or center. Ensures the alignment of coaxial holes or shafts. Checked using axis alignment tools in CAD models. Checked with a dial indicator or CMM.
Angularity Ensures a feature is at a specific angle relative to a datum. Used for angled features such as chamfers or inclined planes. Defined by angular constraints and visual inspection tools. Measured using an angle gauge or sine bar.
Symmetry Ensures balanced dimensions or features about a centerline. Ensures balanced features such as grooves or keyways. Balanced via symmetrical constraints in CAD. Inspected using a comparator or CMM.
Runout Controls surface variation on a rotating part. Applied to rotating parts such as pulleys or gears. Simulated with rotational axis checks in CAD tools. Checked with a dial indicator during rotation.
Total Runout Controls variation across an entire surface of a rotating part. Ensures total surface accuracy for rotating components. Modeled using surface accuracy constraints. Measured using a CMM or advanced runout gauge.
