Urethane Casting Design Guide
Written by
Sylvia Wu
No items found.
On
June 22, 2016
In
Engineering
Written by
Sylvia Wu
Fictiv Manufacturing Engineer. My favorite products are the ones I get to assemble.
Success! Thank you for subscribing the Fictiv Blog!
Expert Design Guidelines for Urethane Cast Parts
If you are familiar with designing parts for injection molding, you can apply the same best practices and rules of thumb to design parts for urethane casting. This guide will teach you the fundamental principles for designing excellent urethane cast parts.
Download Now
Detailed Recommendations to Ensure Your Parts are Made to Spec
Tolerance guidelines for polyurethane materials
Design considerations for parts with letters and logos
Recommendations for part wall thickness
Recommended parameters and geometry for boss design
A Quick Preview of What's Inside
Written by
Sylvia Wu
No items found.
On
June 22, 2016
In
Engineering
Introduction
The rich text element allows you to create and format headings, paragraphs, blockquotes, images, and video all in one place instead of having to add and format them individually. Just double-click and easily create content.
A rich text element can be used with static or dynamic content. For static content, just drop it into any page and begin editing. For dynamic content, add a rich text field to any collection and then connect a rich text element to that field in the settings panel. Voila!
Headings, paragraphs, blockquotes, figures, images, and figure captions can all be styled after a class is added to the rich text element using the "When inside of" nested selector system.
Feature 1
  • A rich text element can be used with static or dynamic content. For static content, just drop it into any page and begin editing.
Feature 1
Feature 1
What’s a Rich Text element?
Static and dynamic content editing
How to customize formatting for each rich text
Written by
Sylvia Wu
