Finishing Services
Nickel Plating
n/a
Smooth finish
Can be applied with
Media Blasting, Tumbling
Nickel plating is a process used to electroplate a thin layer of nickel onto a metal part. This plating can be used for corrosion and wear resistance, as well as for decorative purposes. Once parts are cleaned of debris, they are submerged into an electrolyte solution. A nickel anode is then dissolved into the solution and deposited onto the part, which acts as the cathode in the reaction.
CNC Machining Design Stack: From Design to Prototype
Your comprehensive toolkit for mastering the art of designing parts for CNC machining and seamlessly progressing from concept to prototype. Here’s what’s included:
Finding the Right Secondary Operations after CNC machining, Part I: Heat Treatments
Welcome to the world of post-CNC heat treatment! Now that you’ve successfully CNC machined your parts, it’s time to give them the TLC they deserve. Don’t let those raw components go out into the world without a little extra oomph.  Once you’ve finished CNC machining your parts, your work isn’t done. Those raw components might […]
