Capabilities
CNC Machining Services
Accelerate prototyping, product development and low to mid volume production with a faster, easier way to get precision machined parts. Get your parts in as quickly as 2 days.
ISO 9001 certified, AS 9100 /ISO 13485 Compliant
45+ Certified Materials, 13+ Finishing Options
NADCAP, and NABL approved manufacturing partners.
Hand Metrology, Laser & CMM Inspections
Hardware Installation & Mechanical Assembly
Our CNC Machining Services
CNC Machining Materials
A2 Tool Steel
ABS
Acrylic
Aluminum
Brass
Bronze
Cast Iron
Copper
Delrin
Garolite G-10
HDPE
Invar
Kovar
Magnesium
Nylon
PEEK
Polycarbonate
Polypropylene
PPS
PTFE
PVC
Stainless Steel
Steel
Titanium
Torlon
UHMW
Ultem
Zinc
A2 Tool Steel
A2 Tool Steel has excellent wear resistance and toughness, commonly used to make fixtures, tools, tool holders, gauges, and punches.
Mill Lead Time:
As fast as 7 days
Finishing Options:
Download our CNC Design Guide!
Learn how to control costs, streamline the design and machining process, and ensure quality CNC drilling, milling and turning outcomes.
Download
Precision Machining Tolerance
Metals, PEEK, And
ULTEM with Drawing
Other Plastics
with Drawing
No Drawing
Linear Dimension +/- 0.01 mm
+/- 0.0003 inch
+/- 0.05 mm
+/- 0.002 inch
ISO 2768 Medium
Hole Diameters
(Not Reamed)
+/- 0.008 mm
+/- 0.0003 inch
+/- 0.05 mm
+/- 0.002 inch
ISO 2768 Medium
Shaft Diameters +/- 0.004 mm
+/- 0.00016 inch
+/- 0.05 mm
+/- 0.002 inch
ISO 2768 Medium
Part lengths of up to 48" are available on our platform process dependent. Please inquire about anything larger. Tolerances listed here are minimums for an ideal case. Looser tolerances may be required depending on process, material choice, or part geometry.
Download Tolerance Chart
Finishing Options for CNC Machining
Alodine Aluminum Clear, gold Media Blasting, Tumbling, Type II Anodizing* Type III Anodizing with PTFE*
Anodizing Aluminum Clear, black, grey, red, blue, gold Media Blasting, Tumbling, Alodine*
Hand Polishing Acrylic Enhanced Cosmetic Appearance
Media Blasting Aluminum, Steel, Stainless Steel, Brass, Bronze, Copper All post processes, except Electropolish and Powder Coat
Powder Coating Aluminum, Steel, Stainless Steel Black (20% or 90% gloss), White (20% or 90% gloss)
Tumbling Aluminum, Steel, Stainless Steel, Brass, Bronze, Copper All post processes, except Electropolish and Powder Coat
Vapor Polishing CNC Polycarbonate (Clear, Black) Enhanced Cosmetic Appearance, Near Optically Clear Applications
*Additional finishing options include chromic acid anodizing, cadmium plating, copper plating, titanium anodizing (blue anodizing), gold plating, silver plating, and more. For materials not listed here, please contact us directly.
WORKFLOW AUTOMATION
One Easy-To-Use Platform from Quote to Delivery
From pricing to design feedback to status updates, our platform makes custom part sourcing easy and hassle-free.
Quotes
No more waiting days or weeks to get CNC machining quotes. Fictiv gives you pricing feedback within seconds or minutes.*
Design Feedback
We’ll analyze your parts for manufacturability, giving you full visibility into cost drivers and potential manufacturing risks.
Order Tracking
Get on-demand production status updates for your orders, including access to part photos and inspection data before delivery.
#fictivmade
CNC Machining Parts Made By Fictiv
JOE TEDESCO
Production at the pace of innovation.
JOE TEDESCO
Lead Aerospace Engineer
Heliospace
Download Case Study >
Brian Burns
30% lower overhead costs.
Brian Burns
Co-Founder,
Catalyst Engineering
CNC Machining FAQs
Fictiv provides a variety of lead times to match your budget while maintaining your project timeline. We can supply CNC parts as quickly as two days.
Our machines are capable of tolerances as tight as +/- 0.0002 inches.
What types of materials work with your CNC machines?
Our instant quoted materials can be found here. Not seeing what you are looking for? You can always request a custom material through our custom RFQ process.
Fictiv is SOC 2 Type II Certified (SOC 2). Proof of certification can be supplied upon request. Learn more here!
Can you accommodate rush orders or expedited delivery?
Speed is standard at Fictiv. We offer a variety of costs and lead times to match your requirements. However, if you require faster delivery for a specific quote, please reach out to your sales representative to see if we can accommodate your request.
Are you able to work with complex geometries or 2D drawings?
Fictiv not only supports complex geometries, but we pride ourselves on being able to produce and deliver complex parts. Our platform enables 2D drawing uploads and generates 2D drawings. Our quoting engine then analyzes the drawings for configuration details and special callouts.
Our platform provides free Design for Manufacturability (DFM) feedback pre-order on all quotations. There are two categories of this feedback: 1. “Warning” indicates a design that requires a closer look, but can still proceed with ordering. 1. “Failure” indicates the component has a significant risk of failure during manufacturing. In this case, a design revision must be uploaded prior to check-out. We also have a team of engineers available to provide DFM feedback via email or phone.
Fictiv is ISO 9001 certified, ISO 13485 compliant, and has NADCAP and NABL approved manufacturing partners.
Let’s Build Something Great, Together
Get a Quote Now
Learn More About CNC Machining
ARTICLE
Rapid CNC Machining vs. Traditional CNC Machining
Read more >
ARTICLE
Precision Machined Parts: Fictiv's Comprehensive Guide
Read more >
