CNC Machining Materials
Nylon
Processes
CNC Mill
CNC Lathe
Lead Time
As fast as 3 days
Neutral (slightly translucent), black
Tolerance
No drawing: ISO 2768 medium
Price
Applications
Gears and sliders, large parts, general-purpose, wear & heat-resistance applications
About the Material
Nylon 6/6 is the most commonly used of the Nylon family of plastics. It enjoys relatively high chemical and heat resistance, and is stiff enough to retain its shape, but tough enough not to permanently deform under load.
Two of the most notable use cases for Nylon are in medical devices and electronics insulation, notably screws and spacers for panel mounted circuit boards.
Glass-filled Nylon boasts many great properties such as high rigidity, strength, hardness, toughness and dimensional stability. This material may be used in assemblies requiring mechanical damping or electrical insulation. Common applications include electrical housings, washers, medical devices and aerospace parts.
Nylon 6/6
Tensile Strength
11,200 PSI
Elongation at Break
50%
Hardness
Rockwell R110
Density
1.13 g/㎤
0.04 lbs / cu. in.
Maximum Temp
185° F
McMaster Part Number
8540K323
Nylon (30% Glass-Filled)
Tensile Strength
13,500 PSI
Elongation at Break
3%
Hardness
Rockwell M88
Density
1.13 g/㎤
0.04 lbs / cu. in.
Maximum Temp
230° F
1473t23
Material Finish
Nylon comes in neutral and black colors. Neutral has a milky-white finish and is slightly translucent.
Design Recommendations
Min Wall Thickness
0.5 mm
Min End Mill Size
0.8 mm (0.03 in)
Min Drill Size
0.5 mm (0.02 in)
Max Part Size (xyz, mill)
152 x 394 mm [d,h] (lathe)
Undercuts
Radii : Depth
Cost Saving Tip
Nylon FAQs
Can nylon be machined?
Yes. Nylon 6/6 is the most commonly used of the Nylon family of plastics. It enjoys relatively high chemical and heat resistance, and is stiff enough to retain its shape, but tough enough not to permanently deform under load.
Is nylon a non metal?
Nylon does not have metal in it. It is a strong, stiff engineering synthetic thermoplastic linear polyamide. Nylon is often used as a substitute for low-strength metals.
What is the strongest type of nylon?
Nylon 6/6 has a PSI of 11.2000. It is the most commonly used of the Nylon family of plastics, however, glass-filled Nylon is stronger with a 13,500 PSI. It boasts many great properties such as high rigidity, strength, hardness, toughness and dimensional stability. This material may be used in assemblies requiring mechanical damping or electrical insulation. Common applications include electrical housings, washers, medical devices and aerospace parts.
What is nylon used for in CNC machining?
Two of the most notable use cases for Nylon CNC machining are in medical devices and electronics insulation, notably screws and spacers for panel mounted circuit boards.
The Future of CNC Machining – 2024 and Beyond
In the dynamic world of manufacturing, CNC machining stands at the forefront of innovation. This field is not just about shaping materials; it’s about shaping the future. As we delve into 2024 and beyond, the landscape of CNC machining is evolving rapidly, driven by technological advancements and industry demands.  Throughout this article, we’re using AI […]
CNC Machining Design Stack: From Design to Prototype
Your comprehensive toolkit for mastering the art of designing parts for CNC machining and seamlessly progressing from concept to prototype. Here’s what’s included:
