Engineering Thermoplastic
Delrin
CNC Delrin Parts — Low-Friction, Wear-Resistant Plastic Components
Delrin
Processes
CNC Mill
CNC Lathe
Lead Time
As fast as 3 days
White, black, brown
Tolerance
No drawing: ISO 2768 medium
Price
Applications
High rigidity and strength applications like gears, bushings, and fixtures
Grades
150, AF (13% PTFE Filled), 30% Glass Filled
About the Material
Delrin (generic: acetal) is a low-friction, high-stiffness material. It is used in applications ranging from auto parts to musical instruments. With a relatively high toughness and minimal elongation, Delrin boasts excellent dimensional accuracy.
Fictiv also offers Delrin AF (13% PTFE-Filled) and Glass-Filled Delrin.
When compared with standard Delrin, Delrin AF has an increased coefficient of friction for applications that require lubrication. With an excellent wear resistance, toughness, strength and dimensional stability, this material is often found in load bearing applications such as bushings, bearings, cams, thrust washers, gaskets and valve seats.
Glass-filled Delrin offers superior stiffness and dimensional stability with a high resistance to creep. Glass fibers increase impact resistance and fatigue endurance. This material is commonly used for automotive applications, construction, fixturing, and gear manufacturing.
Precision
Extreme Toughness Icon
Lubricity
Delrin 150
Tensile Strength
9,000 PSI
Elongation at Break
25%
Hardness
Rockwell M90
Density
1.41 g/㎤
0.05 lbs / cu. in.
Maximum Temperature
180° F
Delrin AF (13% PTFE Filled)
Tensile Strength
7,690 - 8,100 PSI
Elongation at Break
10.3%
Hardness
Rockwell R115-R118
Density
1.41 g/㎤
0.05 lbs / cu. in.
Maximum Temperature
185° F
Delrin (30% Glass Filled)
Tensile Strength
7,700 PSI
Elongation at Break
6%
Hardness
Rockwell M87
Density
1.41 g/㎤
0.06 lbs / cu. in.
Maximum Temperature
185° F
Material Finish
Delrin-150 and Glass-Filled Delrin materials are naturally opaque white because of its crystalline structure and has a matte finish. Delrin AF comes in a brown color (pictured on the right).
Design Recommendations
Min Wall Thickness
0.5 mm
Min End Mill Size
0.8mm (0.03 in)
Min Drill Size
0.5mm (0.02 in)
Max Part Size
1200 x 500 x 152 mm [x,y,z] (mill) 152 x 394 mm [d,h] (lathe)
Undercuts
Radii : Depth
Cost Saving Tip
Cost Saving Tip
Cylindrical OD jig grinding finishing of a metal machined part
Precision Grinding: Processes, Tolerances, and When To Use It
Most engineers have a solid feel for what CNC machining can do. But far fewer have a clear picture of…
Learn more >
Machining of a titanium medical implant component
CNC machining is commonly used to manufacture various medical devices—surgical instruments, fixtures, structural elements, fluid-handling parts, and components that attach…
Learn more >
