3D Printing Materials
Vero
Process
Polyjet
Lead Time
As fast as 1 day
White, Black
Resolution
0.016 mm (White), 0.03 mm (Black)
Price
Applications
Visual models, high-accuracy test fits, low-volume production units
Max Print Size
490 x 390 x 200 mm
About the Material
Vero is a family of photopolymer materials used in PolyJet 3D printing technology. These materials are known for their high-quality, fine-detail printing capabilities and come in various colors. Here are some common applications for Vero materials in 3D printing:
Prototyping: Vero materials are often used to create prototypes of products and components during the design and development phase.
Concept Models: Designers and engineers use Vero to quickly iterate and visualize product concepts and designs in various colors.
Architectural Models: Vero is employed to create detailed architectural models and prototypes of building designs, including scaled-down structures and landscapes.
Educational Models: Educational institutions use Vero to create models for teaching various subjects, including engineering, biology, and geology.
Visual Aids: Vero materials are used to create visual aids and models for presentations and educational purposes.
Custom Parts and Components: Manufacturers use Vero to produce custom parts, components, and assemblies for various applications.
Consumer Product Prototyping: Vero is used to prototype consumer products, allowing designers to test form and function.
Medical Models: Vero is employed in the medical field to create anatomical models for surgical planning, medical training, and patient education.
Dental Models: Dentists and dental labs use Vero to produce dental models for the creation of crowns, bridges, and orthodontic appliances.
Artistic and Sculptural Projects: Artists and sculptors use Vero materials for creating intricate art pieces and sculptures that require fine detail.
Miniatures and Collectibles: Vero is used to create miniatures and collectibles for hobbies and collectible markets.
Custom Jewelry: Jewelers and artisans use Vero to create custom jewelry pieces with intricate designs and patterns.
Consumer Electronics Prototyping: It is employed to prototype casings, enclosures, and parts for consumer electronic devices.
Aerospace Models: Vero materials can be used to create detailed aerospace models for visualizing aircraft and spacecraft designs.
Automotive Prototypes: Vero is suitable for prototyping automotive parts and components, including interior features and dashboard designs.
Marketing and Advertising: Vero is used in the advertising and marketing industry to create promotional models, displays, and visual aids.
Packaging Prototypes: Vero can be used to create prototypes of packaging designs, allowing designers to assess visual appeal and functionality.
Functional Testing: In some cases, Vero prototypes can be used for functional testing, especially when high detail and a wide range of colors are required.
Vero materials offer exceptional detail, accuracy, and color options, making them suitable for applications where visual appearance and fine details are critical. These materials are often chosen when the focus is on achieving realistic and aesthetically pleasing prototypes and models.
Tensile Strength
50 MPa (7250 PSI)
Elongation at Break
10%
Modulus of Elasticity
2000 MPa (290000 PSI)
Flexural Strength
75 MPa (11000 PSI)
Material Datasheet
Material Finish
VeroWhite is our high resolution 3D printed material. The material finish is an opaque white and is perfect for visual models and checking the fit and features of your prototype. The layering or stepping is minimally visible due to the color and high resolution of this manufacturing process.
Design Recommendations
Max Part Size [x, y, z]
490 × 390 × 200 mm
19.3 × 15.4 × 7.9 in
Min Clearance + Gaps for Fit
0.2 mm offset on each wall is the recommended gap for enclosures.
Min Wall Thickness
1 mm min
Internal Cavities
Internal cavities are highly discouraged with VeroClear due to the water-based support material that will swell and change the geometry overtime if left inside. Note that support material that has no direct line of sight inside a cavity cannot be cleaned out.
Threads & Inserts
For Vero, we recommend you use either press or heat inserts. For more information, check out our article on The Best Fasteners for 3D Printed Parts.
Text Guidelines
Text should be embossed by at least 1.0 mm to stay visible after printing. Text should also be at least 1.5 mm thick in all areas.
Tolerance
Tolerance for Vero is +/- 0.004”, or +/- 0.001” per inch, whichever is greater.
New DDP and Configuration Options Provide Cost Transparency and Control for Customers Worldwide San Francisco, CA — August 7, 2025 — Fictiv, the trusted global manufacturing and supply chain company, today announced new total landed cost pricing on its platform via Delivered Duty Paid (DDP) and Importer of Record (IoR) configuration options.  With so many […]
FictivMade: Detailed DFM Analysis
Design for Manufacturing (DFM) is a critical component of product development that can make or break your product design. It can be integrated early and often in the process as design revisions are made, ensuring the designer and manufacturer are aligned. However, it can often be more complex and time-consuming than expected. At this stage […]
