Tariff Regulations are Changing Fast - Here's How to Navigate Tariffs with Fictiv: Learn More
Get an Instant CNC Machining Quote
Precision, quality, and efficiency — our state-of-the-art machinery and highly skilled team will exceed your expectations.
Join 4,600+ companies who work with Fictiv
ISO 9001 certified,
AS 9100 / ISO 13485 compliant
icon
Parts Machined as Fast as 1 Day
icon
Hand Metrology,
Laser & CMM Inspections
icon
45+ Certified Materials,
13+ Finishing Options
Trusted by Industry Leaders Nationwide
Confidentiality Assured with NDAs
We understand the importance of safeguarding your confidential information. Rest assured, we gladly accept Non-Disclosure Agreements (NDAs). Submit an inquiry here, and we will follow up with an email providing the next steps.
Our CNC Machining Services
CNC Milling Services
3, 4 and 5-axis machining capabilities for simple and complex geometries.
Part size: up to 48” in length
Tolerance: as tight as +/-0.008 mm,
ISO 2768 Medium without a drawing
Materials: 45+ metal and plastic options
Finishes: 13+ finishing options
CNC Turning Services
Standard and live tooling capabilities for cylindrical parts such as pins, shafts, and spacers.
Electrical Discharge Machining (EDM)
Wire and Sinker EDM are non-contact machining methods for cutting deep pockets, complex internal features, and holes with a keyway.
Min part size: 3.0x3.0x0.3mm
Max part size: 300x300x200mm
Tolerance: ISO grade 7 to 12
Materials: 26+ options
Gear Hobbing Services
A wide range of stock hobbing tools available for quick turnaround times.
Min part size: 1.0x1.0x0.3mm
Max part size: 500x500x800mm
Tolerance: ISO grade 6 to 12
High Volume CNC Machining Services for Production Parts
Serving all your CNC needs up to production quantities, including finishing and machining—all from your 2D drawings.
Large CNC Parts
Custom large CNC parts at scale, ensuring repeatability and reliable quality.
WORKFLOW AUTOMATION
Try Materials.Ai
MaterialsAI
CNC Machining Materials
A2 Tool Steel
ABS
Acrylic
Aluminum
Brass
Bronze
Cast Iron
Copper
Delrin
Garolite G-10
HDPE
Invar
Kovar
Magnesium
Nylon
PEEK
Polycarbonate
Polypropylene
PPS
PTFE
PVC
Stainless Steel
Steel
Titanium
Tool Steel
Torlon
UHMW
Ultem
Zinc
A2 Tool Steel
Mill Lead Time:
As fast as 7 days
Finishing Options:
Precision Machining Tolerance
Metals, PEEK, And
ULTEM With Drawing
Other Plastics
With Drawing
No Drawing
Linear Dimension +/- 0.01 mm
+/- 0.0003 inch
+/- 0.05 mm
+/- 0.002 inch
ISO 2768 Medium
Hole Diameters
(Not Reamed)
+/- 0.008 mm
+/- 0.0003 inch
+/- 0.05 mm
+/- 0.002 inch
ISO 2768 Medium
Shaft Diameters +/- 0.004 mm
+/- 0.00016 inch
+/- 0.05 mm
+/- 0.002 inch
ISO 2768 Medium.
Part lengths of up to 48" available on our platform, process dependant. Please inquire about anything larger. Tolerances listed here are minimums for an ideal case. Looser tolerances may be required depending on process, material choice, or part geometry.
Download CNC Material Datasheet
JOE TEDESCO
Production at the pace of innovation.
JOE TEDESCO
Lead Aerospace Engineer
Heliospace
Download Case Study >
Brian Burns
30% lower overhead costs.
Brian Burns
Co-Founder,
Catalyst Engineering
Get Custom Parts Delivered As Fast As 24 Hours.
Instant pricing & lead-time options
CNC Machining FAQs
icon chevrond down
Fictiv provides a variety of lead times to match your budget while maintaining your project timeline. We can supply CNC parts in a quick as two days.
icon chevrond down
Our machines are capable of tolerances as tight as 0.0002"
What types of materials can your CNC machines work with?
icon chevrond down
Our instant quoted materials can be found (here). Not seeing what you are looking for? You can always request a custom material through our custom RFQ process. Help center
icon chevrond down
Fictiv is SOC 2 Type II certified (SOC 2) and our proof of certification can be supplied upon request.
Can you accommodate rush orders or expedited delivery?
icon chevrond down
Speed is standard at Fictiv, we work to present you with a variety of costs and lead times to match your requirements. However, if you do require even faster delivery for a specific quotation, please reach out to your sales representative to see if we can accommodate your request.
Do you have the capability to work with complex geometries or 2D Drawings?
icon chevrond down
Fictiv not only supports complex geometries, but we pride ourselves on being able to produce and deliver difficult parts. Our platform allow for 2D drawing upload, 2D drawing generation and our quoting engine analyzes the drawings for configuration details and special callouts.
icon chevrond down
Our platform provides free Design for Manufacturability (DFM) feedback pre-order on all quotations. There are two categories of this feedback. A Warning designates a piece of the design that you should have a second look at, but can still proceed with ordering the part as is. If you receive a Failure, it designates that the component has a significant risk of failure during manufacturing and a design revision must be uploaded in order to check-out.
icon chevrond down
Fictiv is ISO 9001 certified, AS 9100 and ISO 13485 compliant
