Keep AI Infrastructure Deployments on Schedule
Fictiv handles your build's custom manufacturing — frames, enclosures, cooling, welded assemblies, and integrated modules. MISUMI supplies the standard hardware. One coordinated path from sourcing to delivery.
Upload your model to get started arrow
AI data center server rack with integrated assemblies, cooling components, and custom frames
Parts as fast as 1 day
Full assemblies delivered to spec
NPI & bridge manufacturing ready
4x Faster than traditional suppliers
Flexible regional sourcing options
Problem / Why Now
Don't Let Delays Derail Your Deployment
AI infrastructure is a deployment race. From land purchase to launch, these builds demand rapid execution across 24–36 months — and engineering teams, procurement leaders, construction program managers, and third-party build teams are all under pressure to keep every phase on schedule.
When teams are ready to move from design validation to deployment, physical hardware sourcing becomes the bottleneck. Traditional Contract Manufacturers are not always set up for NPI, low-volume runs, or the iteration speed these builds demand. This is the agility gap that Fictiv bridges.
Pain Point
Hard to source fast
Low-volume custom hardware is slow to source — from frames and racks to enclosures and cooling components.
PHASE 1
Design Validation
Pain Point
NPI doesn't fit the CM queue
Traditional Contract Manufacturers are not always set up for NPI, bridge production, or program recovery.
PHASE 2: Agility Gap
NPI · Bridge Mfg · Recovery
Where Fictiv bridges the gap
Pain Point
PM overload
Program Managers are stretched thin — juggling multiple vendors, documentation, and complex procurement workflows.
PHASE 3
Full CM Production
What We Source
Custom Infrastructure Components for Deployment-Critical Builds
Frames & structural
FICTIV MISUMI
Frames & structural
Rack frames, brackets, rails, mounting structures, T-slot profiles, H-frames
Enclosures & panels
FICTIV
Enclosures & panels
Sheet metal enclosures, compute trays, louvered panels, airflow panels, L-brackets
Cooling infrastructure
FICTIV MISUMI
Liquid cooling manifolds, cold plates, precision fittings, CDU-related components — designed in from the earliest planning stages
Welded & fabricated
FICTIV
Welded & fabricated
Large-format welded frames and structural assemblies requiring heavy fabrication — not covered by standard machining suppliers
Integrated assemblies
FICTIV MISUMI
Custom-machined parts + MISUMI standard hardware, finished and assembled into more complete assembled modules
Standard & OTS
FICTIV MISUMI
Standard & OTS
Fasteners, screws, bolts, nuts, washers — integrated using the Misumi catalog
Exploded diagram of a data center rack assembly
Why Fictiv
Built to Keep Deployments Moving
Faster access to critical components
Source custom frames, brackets, enclosures, liquid cooling manifolds, cold plates, and airflow panels faster — with responsive manufacturing support.
Integrated assembly support
Custom machined and sheet metal parts combined with MISUMI standard hardware into fully assembled modules — reducing the number of vendors you manage and the work your team does on-site.
Bridge manufacturing & program recovery
When timelines slip, Fictiv steps in — supporting low-volume, deployment-critical builds and bridging the gap before full Contract Manufacturer engagement.
Simplified supplier coordination
One coordinated path for parts, finishing, documentation, and assembly — so teams spend less time chasing vendors and more time keeping builds on track.
Use Cases
Built for the Most Demanding Infrastructure Builds
Deployment-critical components
Frames, racks, enclosures, cooling components, and structural parts that sit on the critical path of the build.
Low-volume, NPI, and delayed-build support before full Contract Manufacturer engagement.
Integrated assembly to reduce on-site work
Custom parts, MISUMI hardware, finishing, and assembly combined into more complete assembled modules.
How It Works
How Fictiv Supports Deployment-Critical Builds
requirements, dfm review, assembly, deployment process image
AI data center hardware validation
Case Study
How Fictiv Helped a Global Consumer Electronics Company Validate AI Data Center Hardware 4x Faster
Challenge
Internal fabrication labs were at capacity. Traditional suppliers could not match the pace, volume, or complexity of the build. With competitive pressure in the AI data center market mounting and an aggressive timeline that could not slip, the team needed a partner that could move fast, manage high complexity, and provide deep DFM support.
Solution
Fictiv supported the program end-to-end — DFM, sourcing, program management, custom manufacturing, and MISUMI OTS components — delivering full assemblies in under 2 months when internal capacity was maxed out and traditional suppliers could not meet the timeline.
Full assemblies delivered in <2 months
Supported by thousands of machined and OTS components.
4x faster than traditional suppliers
Accelerated delivery compared to typical vendor timelines.
3 months pulled forward on timeline
On a program that could not slip.
Read full case study
Ready to Keep Your AI Infrastructure Deployment on Schedule?
Talk to Fictiv about custom components, integrated assemblies, and bridge manufacturing support for your next infrastructure build.
Upload Your Model to Get Started arrow
