INDUSTRIAL MRO SERVICES
MRO services to keep production running when critical parts fail
Reactive MRO means firefighting, manual sourcing, and costs you never see coming. Most programs treat the symptoms. We eliminate the cause—with end-to-end coverage across standard components, custom replacement parts, obsolescence management, and inventory strategy.
parts image
Built for industries where uptime is critical
Icon Image
Factory
Automation
Icon Image
Packaging
Machinery
Icon Image
Robotics &
Motion Systems
Icon Image
Warehouse
Automation
Icon Image
Industrial
Equipment
CUSTOM SOLUTIONS
Solve MRO problems at every stage
Every solution is built custom—covering mechanical BOM sourcing, reverse engineering, replenishment, supply chain orchestration, and inventory management. We work from any manufacturing system, including:
01 · GREENFIELD
New Manufacturing Systems
We source and consolidate everything you need to launch new assembly lines, robotic cells, and factory automation systems, including precision replacement parts and preventative maintenance planning from day one.
02 · SCALE
Scaling Manufacturing Systems
As production ramps up, we help standardize MRO supply chain operations, support contract manufacturers, and streamline factory automation component sourcing globally.
03 · LEGACY
Legacy Equipment & Obsolescence
For old equipment no longer supported by OEMs, we source obsolete industrial parts, reverse engineer components without 2D drawings, and extend equipment lifespan with custom spare parts.
Source standard parts and precision replacement parts together
WHO WE SERVE
Built for every team that keeps production moving
MECHANICAL / DESIGN ENGINEERING
KPI: Time-to-Prototype
Iterate in days, not weeks
Get custom and configurable parts on demand. No RFQ friction or waiting on procurement to open a new vendor.
10 → 3 days
Faster from design to hand
MFG / OPERATIONS ENGINEER
Keep the line running
Right part at the cell before a stockout becomes a stoppage. Point-of-use availability with automated replenishment.
5 - 15%
OOE Improvement
MAINTENANCE / MRO ENGINEER
Fix equipment faster
Every spare available 24/7 with full traceability and audit trail. Less time searching, more time wrenching.
30 - 60%
Less time searching
SUPPLY CHAIN / PROCUREMENT
Replace 8-15 suppliers with one program
Real-time spend visibility, automated replenishment, and consumption-based billing.
50% reduction
Procurement Cost
One Connected System
One source of truth for parts, people, and performance across your entire factory.
Engineer MRO Operation Procurement
One Program.
One Source.
Zero Friction.
Parts at the point of use - always.
WHAT WE DELIVER
Industrial MRO services, start to finish
Catalog fasteners to reverse-engineered custom replacement parts, and everything in between. If it keeps your line running, we can source it, configure it, or manufacture it.
off the shelf parts
STANDARD
Off the Shelf
  • MISUMI catalog parts
  • Stock fasteners & hardware
  • Electro-mechanical (motors)
  • Electrical controls (PCBA)
made to order parts
CONFIGURABLE
Made to Order
  • MISUMI configurable components
  • Lengths, materials, tolerances
  • Design-to-order catalog items
custom mechanical parts
MANUFACTURED
Custom Mechanical
  • Fictiv CNC machined parts
  • Injection molded components
  • 3D printed / additive
  • Sheet metal parts & assemblies
services
CONSULTATIVE
Engineering Services
  • Reverse engineering (3D scan to CAD)
  • PM process plan development
  • BOM consolidation or redesign for manufacturability
  • Tooling for high-volume parts
  • Reactive → preventative MRO strategy
inventory logistics
MANAGED
Inventory & Logistics
  • On-premise inventory management
  • JIT inventory strategy at MISUMI warehouses
  • 3rd Party Logistic
HOW IT WORKS
How emergency MRO support works
Automated procurement of standard parts, on-demand manufacturing of custom and precision replacement parts, deep analytics, and everything else you need to keep running like clockwork.
01
Identify
  • Equipment risk assessment
  • Obsolescence detection
  • Inventory optimization
  • Legacy part records
02
Procurement
  • Global sourcing
  • On-demand manufacturing
  • Automated ordering
  • Lifecycle purchasing
03
Receiving
  • Incoming inspection
  • PO verification
  • Quality documentation
04
Storage
  • Optimized inventory strategy
  • Proper warehousing
  • JIT delivery
  • Digital archives
05
Distribution
  • Work orders
  • Pick, pack & fulfillment
  • Emergency production
  • Field service support
06
Analytics
  • Usage monitoring
  • Cost analysis
  • Obsolescence forecasting
OBSOLESCENCE MANAGEMENT
Don’t wait for obsolete industrial parts to stop your line
Your equipment is built to last 20-30 years. Critical parts have a support window of 3-7 years. The gap between those numbers is where downtime happens, and where reactive maintenance gets expensive.
EQUIPMENT LIFECYCLE TIMELINE
Risk grows as the support gap widens
YEARS 1-5
Low risk
Line running at full throughput
OEM support and standard parts readily available.
YEARS 6-10
Watch
Risk begins: early obsolescence
Parts become harder to source as OEMs redesign products.
YEARS 11-20
Action needed
Uptime seriously at risk
Reverse engineering and on-demand manufacturing become critical.
YEARS 21-30
Critical
Obsolescence → reactive maintenance
Unsupported parts require manual sourcing and custom fabrication.
20-30
YEARS
systems last
3-7
YEARS
critical parts last
Without a plan, that gap costs you:
  • Unplanned downtime from failed or unavailable parts
  • Scrambled sourcing and missing documentation
  • Costly emergency expedites and workarounds
PILOT ROADMAP
Get your custom MRO solution built and running in 90 days
A structured pilot designed to prove value, and lock in a preventive maintenance and sourcing strategy, before you commit to full deployment.
STEP 01
Audit & Discovery
Walk the floor, inventory critical equipment, map current MRO spend, identify highest-risk obsolescence exposure.
DAYS 0–15
STEP 02
Design the Program
Build the BOM, scope vendor consolidation, design the inventory model, and identify candidates for custom replacement parts.
DAYS 15-45
STEP 03
Pilot Implementation
Stand up vending or managed inventory at the pilot cell, integrate procurement systems, train the maintenance team.
DAYS 45-75
STEP 04
Measure & Scale
Quantify savings, OEE lift, and downtime reduction. Define expansion roadmap for the rest of the facility or network.
DAYS 75-90
GET STARTED
Ready to stop fighting downtime fires?
Talk to an expert about consolidating your MRO services into a single 90-day pilot for your facility.
Talk to an MRO expert
