Fictiv Manufacturing Network
Inside the Factory
An insider look at the scale, capability, and quality of Fictiv’s vetted and managed global manufacturing network.
Global Reach
5 regions
Production Capacity
100+ facilities
Lead Times
as fast as 1 day
Certifications
ISO 9001 & AS9100
Global supply regions
USA USA
Mexico Mexico
China China
India India
Japan Japan
United States Manufacturing Network
A sample of our manufacturing partners—part of a vetted global network of 250+.
Prototek
Prototek
  • AS9100D-certified CNC machining, additive manufacturing, sheet metal fabrication, urethane casting, and mechanical assembly.
  • CMMC Level 2 and ITAR registered—one of Fictiv’s core partners supporting export-controlled applications.
Fictiv Local
Fictiv Local
  • A network of franchise machine shops that meet Fictiv’s quality standards and support fast-turn CNC machining. Learn more about Fictiv Local.
Mexico Manufacturing Network
Sheet Metal Capabilities
  • Network of 8 sheet metal manufacturing partners
  • Slitter: max 7 cuts, 24 GA
  • Cutting processes: CO2 & fiber laser, waterjet, plasma
  • Punching up to 30 tons capacity
  • Stamping up to 440 tons capacity
  • Bending up to 320 tons capacity
  • Tube laser cutting: diameter up to 6″, thickness up to ½″, length up to 21 ft
  • Robotic and manual welding cells
  • Powder coat: continuous lines and batch ovens
  • Secondary processes: e-coat, electroplating, galvanizing, heat treatment
  • Assemblies
Injection Molding Capabilities
  • Network of 6 injection molding manufacturing partners
  • 100+ presses, from 70 ton up to 3,000 ton
  • Overmolding, gas-assist molding, in-mold decorating/labeling, multi-shot molding, insert molding, stack molds
  • Vibration & ultrasonic welding
  • Manual hardware and automated complex assemblies
  • Secondary processes: plating, chrome, painting, laser engraving, pad printing, hot stamping, silk screen
DIMET
DIMET
Sheet Metal Solutions
  • End-to-end sheet metal capabilities: 25+ laser machines, 20+ CNC bending machines, 2 powder coat lines, stamping, CNC machining, manual and robotic welding
  • Advanced, scalable infrastructure for high-quality production
  • 600K sq ft of production space across 3 buildings
  • Certified: ISO 9001, AWS welding certification
MAIS
MAIS
Aerospace CNC Machining
  • One-stop shop with AS9100D & NADCAP-certified 3- and 5-axis machining, plus in-house anodizing and chemical film processing
  • Core business is high-volume aerospace programs
  • Advanced quality equipment, including CMM and FARO Arm, for high-quality output at scale
EVCO
EVCO
Industrial Injection Molding
  • Injection molding shop with presses from 70–3,000 ton, plus plastic welding and assembly capabilities
  • Overmolding, gas-assist molding, multi-shot molding
  • Certified: IATF 16949 for automotive
India Manufacturing Network
Ace Multi Axes Systems Ltd
  • AS9100D-certified machining, casting, and assembly under one roof
  • High-mix, complex component expertise, machining from a few millimeters up to 10,500 mm
  • 30+ years of manufacturing excellence, with an 80,000–200,000+ sq ft footprint
Spacenex
Spacenex
  • Integrated aerospace solution: AS9100D machining combined with NADCAP-approved special processes
  • High-precision manufacturing with tight tolerances and repeatable quality
  • End-to-end capability—machining, NDT, and special processes delivered in-house
Magod Laser
Magod Laser
  • End-to-end laser manufacturing: 2D/3D and tube cutting, 5-axis laser cutting, CNC bending, and fabrication
  • Advanced, scalable infrastructure for precision and high-volume production
  • Certified: NADCAP welding, AS9100 compliance
China Manufacturing Network
Fictiv Injection Molding Facility
  • Fast, high-quality custom manufacturing with built-in tariff mitigation benefits
  • ISO 9001-certified quality management system
  • CNC machining, injection molding, 3D printing, sheet metal fabrication, and die casting
Fictiv CNC Machining Facility
CNC Machining Equipment
  • Röders RXH 601 DSH, 5-axis (42,000 RPM)
  • Röders RXP 501, 3-axis (42,000 RPM)
  • Makino V33i, Makino EDGE 3i
Fictiv China CNC Machining
CNC Machining: Makino V90S-5 Axis Machine
  • Five-axis continuous processing platform designed for large die/mold part machining
  • Tilting/rotating spindle extends tool life
  • Delivers outstanding surface finishes, minimizing post-machining hand work
See inside our manufacturing facilities
A look at the floors, equipment, and quality controls behind every part we make.
Hear from our partners
“With over 20 years of expertise in die casting, we serve a diverse range of customers across multiple industries. We manufacture 100+ types of components through high-volume die casting, catering to automotive, non-automotive, electrical, home appliance, and medical applications. Our capabilities extend beyond domestic markets, with reliable dispatch and supply to customers internationally.”
Ajaykumar Jha
Ajaykumar Jha
Director of Mass Die Casting, Pune, India.
Ajaykumar Jha
Want to see Fictiv’s manufacturing excellence firsthand?
Fictiv manufacturing equipment
