Finishing Services
Media Blasting
n/a
Applications
Cosmetic parts (the surface of your Macbook Pro has been bead blasted)
Matte
Media blasting uses a pressurized jet of abrasive media to apply a matte, uniform finish to the surface of parts. The most common media used are varying sizes of glass beads or sand, though for other levels of abrasion, things like plastic beads have also been used.
This process is used to create a uniform, matte finish on parts, but can also be used to hide machine marks or remove small flaws in parts prior to anodizing or other plating processes.
Design considerations
  • Avoid blasting thin walls, as they are prone to deformation.
  • Parts with intricate geometries may be difficult or impossible to uniformly finish.
Designing Structural Links for Robotic Arms: Materials and Design for Manufacturing
A robot arm can assemble cleanly, pass every bench check, and still miss its target in the field. The problem often starts with the structural links, or the rigid segments that connect one joint to the next. Link design problems tend to fall into three groups: The first two problems trace back to one tradeoff. […]
Choosing the Right Stainless Steel for Your Manufacturing Program
Picture a food mixing agitator that runs fine for a year. Then salty product and the daily sanitizing cycle find the crevice where a paddle meets the hub, and pitting starts under a surface that still looks clean. The drawing said “stainless.” It just didn’t say which one. Stainless steel is a family of alloys […]
