Compression Molding Services
Experience lower tooling costs than injection molding with high-quality, durable parts.
Access to a Fortune-500 global supply chain
9 Certified Materials, 3 Post Processing Options
Material Certification, Certificate of Compliance, Advanced Inspection
Hardware Installation, Mechanical Assembly
Why Fictiv for
Compression Molding
High-quality molded rubber and composite parts with lower tooling costs.
Parts As Fast As 10 Days
  • Tight Tolerances as Low as +/- 0.02” With Drawings
  • Full-BOM Support Including Assembly and Hardware Installation
  • Ideal for Low to Medium Volumes and Large, Complex Parts
  • Certified Materials Including Silicone, EPDM, SBR, FKM, and Polyurethane
  • Finishing Options: SPI Polished, MoldTech Textures, Pad Printing
  • Color Matching to Pantone or RAL Standards
  • Inspection Reports With Every Order
WORKFLOW AUTOMATION
Try Materials.Ai
MaterialsAI
Compression Molding Materials
  • Silicone
  • SBR
  • Natural Rubber (NR).
  • Neoprene (CR)
  • NBR (Buna-N)
  • FKM (Viton)
  • HNBR
  • Polyurethane (PU)
  • EPDM Rubber
Precision Molded Tolerance
With Drawing Without Drawing
Linear Dimension +/- 0.01 mm
+/- 0.004 inch
SPI Commercial
Hole Diameters +/- 0.005 mm
+/- 0.002 inch
SPI Commercial
Part lengths of up to 1000mm*600mm available on our platform, process dependant. Please inquire about anything larger.
Tolerances listed here are minimums for an ideal case. Looser tolerances may be required depending on process, material choice, or part geometry.
Compression Molding Finishing Options
All finishes meet SPI standards
Finishes
SPI polished finishes and MT (MoldTech) textured finishes.
Pad Printing
Applying an ink-based, 2D design to a 3D surface.
Color Matching
Standard colors plus matching to Pantone or RAL number.
JOE TEDESCO
JOE TEDESCHO
Lead Aerospace Engineer
Heliospace
Download Case Study >
ANDREW WILLING
Mechanical Engineer
HEBI Robotics
JON HOBGOOD
Unrivaled customer service
"Fictiv does an incredible job connecting my needs as a customer to those suppliers that have the capability, the right competitive cost, and the capacity to build my product and get it to me in a very rapid cycle time."
JON HOBGOOD
Vice President,
Advanced Manufacturing and Automation
Honeywell Aerospace
Get a quote now
Learn More about Compression Molding
ARTICLE
In today’s competitive global market, cost-conscious design is a strategic necessity. While innovation, quality, and speed to market remain vital,…
Read more >
ARTICLE
Design for Reliability (DFR): Engineering Quality Products That Last
Product reliability is a critical measure of success in industries where failure is not an option. A single malfunction can…
Read more >
ARTICLE
New DDP and Configuration Options Provide Cost Transparency and Control for Customers Worldwide San Francisco, CA — August 7, 2025…
Read more >
