Home   ›   Specifications   ›   3D Printing Technologies & Guidelines
3D Printing Specifications & Guidelines
6 addictive technologies with specs, materials, and design tips per process
Dropdown labeled Process with '3D Printing' selected and a green 'Apply configuration' button over a teal background showing a 3D printer component
3D Printing Technology Comparison ▾
Technology Layer Height Min Wall Tolerance Best For
FDM 0.1–0.3mm 0.8mm ±0.5mm Prototyping, functional
SLA 0.025–0.1mm 0.4mm ±0.15mm High detail, smooth
SLS 0.1mm 0.7mm ±0.3mm Functional, no supports
MJF 0.08mm 0.5mm ±0.3mm Production volume
PolyJet 0.016mm 0.5mm ±0.1mm Multi-material
Carbon DLS Variable 0.5mm ±0.1mm Production grade
FDM — Fused Deposition Modeling ▾
  • Most common. Thermoplastic filament layer-by-layer.
  • Materials: PLA, ABS, PETG, Nylon, TPU, PC, CF Nylon, ULTEM
  • Anisotropic — weakest in Z. Overhangs >45° need supports.
  • Min feature: 0.4mm (nozzle dependent)
SLA — Stereolithography ▾
  • UV laser cures photopolymer. Best surface finish.
  • Materials: Standard, Tough, Flexible, Castable, High-Temp, Clear resins
  • XY resolution: 0.05–0.15mm. Parts need UV post-cure.
SLS — Selective Laser Sintering ▾
  • Laser fuses powder. No supports — powder bed supports part.
  • Materials: Nylon PA12, PA11, Glass-Filled, CF Nylon, TPU
  • Escape holes (Ø≥5mm) needed for hollow parts.
MJF — Multi Jet Fusion ▾
  • HP production-grade. Faster than SLS, isotropic properties.
  • Materials: PA12, PA11, PA12 Glass Bead, TPU
  • Excellent for medium-volume production runs.
PolyJet & Carbon DLS ▾
  • PolyJet: Highest resolution (0.016mm layer). Multi-material/color.
  • Carbon DLS: CLIP technology. Injection-mold-quality finish.
  • Carbon materials replace IM components in production.
General Design Best Practices for Additive Manufacturing ▾
  • Orient to minimize supports
  • Consider build orientation for strength
  • Add fillets at stress points
  • Escape holes for powder processes
  • Wall >2mm for structural. Avoid large flats.
  • Test fit tolerances with pilot prints
