Home     Specifications     Injection Molding
Injection Molding Specifications and Guidelines
Wall thickness, draft angles, ribs, gates, shrinkage, SRI finishes, and cost optimization.
2°–3°
Rec. Draft
2-3mm
Nominal Wall
±0.030"
Standard Tol
10 Days
T1 Samples
Configuration panel: Process set to Injection Molding with an 'Apply configuration' button on a teal background and a 3D orange injection mold in the background.
Wall Thickness & Uniformity
Material Range
ABS 1.2–3.5mm
Polycarbonate 1.0–4.0mm
Polypropylene 0.8–3.8mm
Nylon 0.8–3.0mm
PEEK 0.5–3.0mm
  • Maintain uniform ±10%. Thick = sink marks.
  • Transitions 3:1 ratio max. Core out thick areas.
Draft Angles
Material Draft
Rigid (ABS, PC) 0.5°–2°
Semi-rigid (PP, PE) 0.5°–1.5°
Flexible (TPE) Can be 0°
Textured 0.5 - 1.5
Ribs, Bosses & Gussets
  • Rib: 50–65% wall, height:thick 3:1 max
  • Boss OD: 2× internal Ø. Wall 60% nominal.
  • Gussets: 50–65% wall. Radius at intersections.
  • Fillet at rib base ≥0.25× wall
Gates & Runners
  • Edge: Common, visible mark. Tunnel: Auto-degate.
  • Pin Point: Small mark, hot runner. Fan: Wide, low shear.
  • Tab: Gate on tab. Hot Tip: Minimal vestige.
  • Place at thickest section. Avoid cosmetic surfaces.
Shrinkage by Material
Material Shrinkage
ABS 0.4–0.7%
PC 0.5–0.7%
PP 1.0–2.5%
Nylon 1.0–1.5%
Nylon GF 0.2–1.0%
Acetal 1.5–3.5%
PEEK 1.2–1.5%
SPI Surface Finish Standards
Grade Description Ra
A-1 to A-3 Mirror polish 0.012–0.05μm
B-1 to B-3 Semi-gloss 0.05–0.1μm
C-1 to C-3 Matte 0.35–0.7μm
D-1 to D-3 Textured 0.8–3.2μm
Cost Optimization
  • Simplify: fewer features = simpler mold
  • Use adequate draft. Avoid undercuts.
  • AL molds for proto (<10K shots)
  • Family molds for related assemblies
Ready for injection molding?
T1 samples in 10 days with DFM support.
