Latest articles
Torlon® (PAI): A High-Performance Plastic With Advanced Material Properties
Torlon®, the brand name for polyamide-imide (PAI), is an ultra-high-performance thermoplastic known for its exceptional mechanical strength, thermal stability, and chemical resistance.  It has the highest strength and thermal resistance of any melt-processable plastic, with continuous use temperatures up to 260°C. Torlon is often used in extreme conditions, such as aerospace, oil & gas, and […]
Soft Polymers for Product Design: Comparing Flexible Materials
In product design, many situations call for soft or flexible materials. Whether it’s a waterproof seal or a compliant mechanism, these types of materials prove indispensable in many use cases. The right material choice can mean the difference between a product that merely meets basic requirements and one that excels in comfort, durability, and performance. […]
POM(Acetal/Delrin®) Plastic: Properties, Advantages, and Material Comparisons
Imagine designing a complex assembly with rotating parts that come into contact with each other. You have dialed in your dimensions and tolerances, ordered fasteners, and assembled your prototype parts. But as you rotate the components, they bind against each other, or even make grinding or squeaking noises. In this case, you may need a […]
Fictiv Transforms Injection Molding Services
Trusted global manufacturing and supply chain leader delivers best-in-class injection molding experience with advanced DFM tools and unmatched mold build visibility San Francisco, CA — July 22, 2025 — Fictiv, the global manufacturing and supply chain company, today announced significant advancements in its injection molding capabilities, reinforcing its position as the easiest and most reliable […]
Exciting Update! Fictiv’s Injection Molding Platform Experience
Injection molding is already a complex process without the added stress of complicated ordering procedures. Engineers and sourcing managers today face increasing demands and simply don’t have time for the extra headache of chasing down supplier quotes. With so many things that can go wrong in the molding process that require careful design and planning […]
Boring vs. Drilling vs. Reaming: A Guide to Precision Hole Machining
High-quality hole machining is critical for manufacturing parts with tight tolerances. Holes need to align with precision and accuracy, especially for functional assemblies and engineering fits. Drilling, boring, and reaming are distinct machining processes used to create or refine holes, each offering different levels of precision and surface finish. However, these terms are often mistakenly […]
Plastic Fillers: Glass, Carbon, and Mineral-Filled Thermoplastics for Engineering Applications
Filler materials or compounds can be added to thermoplastics to improve their mechanical properties, lower material costs, or achieve a combination of both. The properties of filled thermoplastics can vary depending on the type of base plastic, the type of filler used, and the filler concentration. These improved characteristics make filled thermoplastics valuable across various […]
FictivMade: Detailed DFM Analysis
Design for Manufacturing (DFM) is a critical component of product development that can make or break your product design. It can be integrated early and often in the process as design revisions are made, ensuring the designer and manufacturer are aligned. However, it can often be more complex and time-consuming than expected. At this stage […]
Fictiv Receives Frost & Sullivan’s 2025 Global Supply Chain for Custom Mechanicals Technology Innovation Leadership Recognition
For its strong performance and innovative technology, Fictiv is presented with Frost & Sullivan’s 2025 Global Technology Innovation Leadership Recognition in the supply chain for custom mechanicals. Click here to read the report.
SAN ANTONIO, TX. – July 7, 2025– Frost & Sullivan is pleased to announce that Fictiv, a global manufacturing and supply chain company, has received the 2025 Global Supply Chain for Custom Mechanicals Technology Innovation Leadership Recognition for its outstanding achievements in technology innovation, digital orchestration, and customer value creation. Frost & Sullivan evaluates companies […]
