Latest articles
CNC machining involves far more than simply uploading a CAD model and cutting parts. Every part is shaped by the material, machine types, cutting tools, finishes, and design constraints that work together to determine cost, quality, and performance. To help engineers better understand these relationships, the Fictiv team created the CNC Periodic Table of Elements—a […]
Overmolding Materials Guide: Material Bond Compatibility
Overmolding is widely used to combine materials with different properties—such as rigid substrates and soft-touch elastomers—into a single component. Common examples include tool grips, seals, and consumer products like toothbrushes. However, successful overmolding depends heavily on material compatibility. Poor adhesion between materials can lead to delamination and part failure, making proper material selection and interface […]
Manufacturing Process Cost & Lead Time Comparison
How to choose between CNC vs. Injection Molding vs. Sheet Metal vs. 3D Printing vs. Die Casting Finding the lowest-cost manufacturing process can be harder than you might think. Cost isn’t a static attribute of a part; it’s a dynamic variable influenced by volume, part geometry, speed to market, and many other factors. Industry data […]
Material Selection for Medical Device Manufacturing: The Best Medical Grade and Biocompatible Options
Medical device materials must meet strict requirements for biocompatibility, sterilization compatibility, traceability, and regulatory documentation. Engineers selecting materials for medical device development must balance mechanical performance, manufacturability, cost, and regulatory compliance across the entire development lifecycle—from early prototypes to full-scale production.  Medical devices range from simple disposables to complex multi-material systems. This guide explains common […]
Rugged Hardware Design for Harsh Environments: Materials, Sealing, and Reliability Strategies
Harsh environments call for rugged hardware. Just how rugged depends on the specific environmental conditions the product will face. Designing ruggedized hardware for unforgiving environments requires understanding the conditions a product will encounter in service and accounting for them before the design is finalized. Engineers must anticipate how temperature extremes, moisture, vibration, UV exposure, and […]
Environmental Resistance of Materials: Chemical, Thermal & Corrosion Performance Compared
Environmental resistance describes a material’s ability to withstand chemical exposure, corrosion, UV radiation, moisture, and elevated temperatures without degrading. When selecting plastics or metals for CNC machining, injection molding, or sheet metal fabrication, engineers must evaluate long-term durability under real-world operating conditions.  This guide ranks common engineering materials by overall environmental durability, corrosion resistance, and […]
High-Pressure Engineering in a Small Form Factor The Breville Bambino Plus compresses key espresso machine architectures—thermal management, pump-driven pressure control, and automated milk texturing—into a compact footprint. At the $500 price point, it occupies the middle ground between entry-level (home) and professional-grade (fancy bistro). After unboxing, we did what any sane engineering team would do: […]
MISUMI Announces Strategic Partnership with Oishii Farm Corporation
Investment strengthens digital manufacturing capabilities to support AI, robotics, and automation in the rapidly growing agritech industry. Tokyo, Japan and San Francisco, CA – March 16, 2026 – MISUMI Group Inc. (Head Office: Chiyoda‑ku, Tokyo; Representative Director and President: Ryusei Ono; hereinafter “MISUMI”) today announced on March 16, 2026, that it has entered into a […]
Fictiv Launches Instant Online Quoting for Injection Molding Parts
Fictiv now offers instant online quotes for qualifying injection molding parts. Upload straight-pull part designs to get legitimate pricing and lead times in seconds—without waiting days for a manual RFQ. For more complex parts, Fictiv’s team of engineering experts still provides custom quotes and design-for-manufacturability support. Injection Molding Quotes—Now Instant  For decades, getting an injection […]
