Rigid Photopolymer
Vero
PolyJet Vero — Rigid High-Detail Prototype & Concept Models
Vero
Process
Polyjet
Lead Time
As fast as 1 day
White, Black
Resolution
0.016 mm (White), 0.03 mm (Black)
Price
Applications
Visual models, high-accuracy test fits, low-volume production units
Max Print Size
490 x 390 x 200 mm
About the Material
Vero is a family of photopolymer materials used in PolyJet 3D printing technology. These materials are known for their high-quality, fine-detail printing capabilities and come in various colors. Here are some common applications for Vero materials in 3D printing:
Prototyping: Vero materials are often used to create prototypes of products and components during the design and development phase.
Concept Models: Designers and engineers use Vero to quickly iterate and visualize product concepts and designs in various colors.
Architectural Models: Vero is employed to create detailed architectural models and prototypes of building designs, including scaled-down structures and landscapes.
Educational Models: Educational institutions use Vero to create models for teaching various subjects, including engineering, biology, and geology.
Visual Aids: Vero materials are used to create visual aids and models for presentations and educational purposes.
Custom Parts and Components: Manufacturers use Vero to produce custom parts, components, and assemblies for various applications.
Consumer Product Prototyping: Vero is used to prototype consumer products, allowing designers to test form and function.
Medical Models: Vero is employed in the medical field to create anatomical models for surgical planning, medical training, and patient education.
Dental Models: Dentists and dental labs use Vero to produce dental models for the creation of crowns, bridges, and orthodontic appliances.
Artistic and Sculptural Projects: Artists and sculptors use Vero materials for creating intricate art pieces and sculptures that require fine detail.
Miniatures and Collectibles: Vero is used to create miniatures and collectibles for hobbies and collectible markets.
Custom Jewelry: Jewelers and artisans use Vero to create custom jewelry pieces with intricate designs and patterns.
Consumer Electronics Prototyping: It is employed to prototype casings, enclosures, and parts for consumer electronic devices.
Aerospace Models: Vero materials can be used to create detailed aerospace models for visualizing aircraft and spacecraft designs.
Automotive Prototypes: Vero is suitable for prototyping automotive parts and components, including interior features and dashboard designs.
Marketing and Advertising: Vero is used in the advertising and marketing industry to create promotional models, displays, and visual aids.
Packaging Prototypes: Vero can be used to create prototypes of packaging designs, allowing designers to assess visual appeal and functionality.
Functional Testing: In some cases, Vero prototypes can be used for functional testing, especially when high detail and a wide range of colors are required.
Vero materials offer exceptional detail, accuracy, and color options, making them suitable for applications where visual appearance and fine details are critical. These materials are often chosen when the focus is on achieving realistic and aesthetically pleasing prototypes and models.
Precision
Extreme Toughness Icon
Aesthetic
Tensile Strength
50 MPa (7250 PSI)
Elongation at Break
10%
Modulus of Elasticity
2000 MPa (290000 PSI)
Flexural Strength
75 MPa (11000 PSI)
Material Datasheet
Material Finish
VeroWhite is our high resolution 3D printed material. The material finish is an opaque white and is perfect for visual models and checking the fit and features of your prototype. The layering or stepping is minimally visible due to the color and high resolution of this manufacturing process.
Design Recommendations
Max Part Size [x, y, z]
490 × 390 × 200 mm
19.3 × 15.4 × 7.9 in
Min Clearance + Gaps for Fit
0.2 mm offset on each wall is the recommended gap for enclosures.
Min Wall Thickness
1 mm min
Cost Saving Tip
Cost Saving Tip
rapid prototyping lead time enables more iterations
Prototyping Lead Time: Process Timelines and How to Reduce Delays
Prototyping lead time is often framed as a simple question: “How long will it take to get my part?” In…
Learn more >
When designing a product, consider all factors that will contribute to its success throughout the development process. For most companies,…
Learn more >
