Urethane Casting Service
  • Instant quotes & DFM feedback
  • Production grade quality
  • Parts as fast as 7 days
No minimum order quantities
Production Quality at Low Volumes
The urethane casting process is a quick, cost-effective way to produce 10-200 units with production-level quality. Typically, each silicone mold will produce 20 castings.
Complex Elastomeric Parts
Urethane casting is ideal for prototyping elastomeric parts such as complex gaskets and overmolds on rigid parts.
High Level of Detail
Urethane casting allows for almost limitless complexity, including sharp internal corners unachievable with CNC machining, and designs without draft or uniform wall-thickness that can’t be injection molded.
Why Fictiv for Urethane Casting
Production-quality prototypes with superior aesthetics and performance.
Parts As Fast As 10 Days
  • Ideal for Complex Geometries & Custom Textures
  • Highly Vetted Domestic & Overseas Partners
  • No Minimum Order Quantity
  • Wide Range of Materials (ABS-like, PC-like, Nylon-like, Elastomers & More)
  • Wide Range of Metals and Plastics
  • Secondary Processing (Painting, Overmolding, Insert Installation)
  • Instant Quotes & Online Order Tracking
WORKFLOW AUTOMATION
Try Materials.Ai
MaterialsAI
Materials
Finishes
Secondary Options
Urethane Casting Materials
ABS-Like
ABS-like FR V0
ABS-like, HT
Acrylic-Like
Nylon-like
Opaque Elastomer
POM-like
PP-like
Waterclear Elastomer
ABS-Like
Material Properties:
Hardness: 75-85 Shore D
Tensile Strength (Mpa): 42-73
Elongation %: 16-21
Impact Strength: 12 kJ/m2 0.58-2 ft-lb/in
Urethane Material Grade (Overseas):
Axson UP 8150
Urethane Material Grade (Domestic):
Rampf TP 4056
Color:
Natural, Yellow, Purple, Color Match
Urethane Casting Case Study
LIM Case study logo image
Urethane cast parts used in a prothesis
close up of urethan cast parts in a prothesis joint
different prothesis parts made with urethane casting
"I love the web portal — it’s quick, simple, and easy to use. The instant feedback is a great way to check my work and then make any necessary revisions to improve the design or lower the cost."
Preston Fung
R&D Engineering Manager, Lim Innovations
Hundreds of quality parts for prosthetic devices icon
10 day production icon
10 day production
Fictiv Urethane Casting Advantages
From Prototype to Production
Concept Stage
Urethane Casting
Looks-like models for marketing photography, investor pitches, and trade shows
Early Prototyping Stage
Urethane Casting
Prototype elastomeric parts such as complex gaskets
Late Prototyping Stage
Urethane Casting
Cost effective way to produce 100 EVT units before cutting injection molding tool
Low-volume Production
Urethane Casting
Low-volume production orders for customized, small-batch products (20-200 units at a time)
Our Quality Promise
  • Inspection reports included with every order
  • 100% visual inspection for every urethane cast part
  • Highly vetted urethane casting partners
  • Quality guaranteed. If your parts aren’t made to spec, we’ll make it right.
Technology Overview
What is Urethane Casting
About the Urethane Casting Process
Urethane casting (also known as RTV molding, cast urethane, and silicone molding) is a fabrication method that uses silicone molds to produce production-quality plastic parts. Urethane Casting production consists of three main steps: ‍ 1. Build a master pattern using 3D printing or CNC machining 2. Build the mold by pouring platinum silicone around master 3. Pour liquid polyurethane resin into mold, create polyurethane casting under vacuum
Advantages of Urethane Casting
With urethane casting, you can get production quality parts at low volumes and without the high costs and lead times of steel or aluminum tooling. This is helpful for bringing new products to market where you may want production-grade products to test with new customers and markets and validate your design hypotheses before making a substantial investment to scale manufacturing.
Urethane Casting Design Considerations
If you are familiar with designing parts for injection molding, you can apply the same best practices and rules of thumb to design parts for urethane casting.
Living Hinge Design: How to Design a Living Hinge
A living hinge is a thin, flexible strip made from the same material as the connected parts, designed to let them bend or rotate without additional hardware. They are low-cost, easy to manufacture, and have little wear or friction involved in operation. But while the idea is simple, the execution can be more complicated. Living […]
