Latest articles
The Top AI Tools Helping Mechanical Engineers in Product Design and Development
Originally published December 2025 | Updated November 2026 | By David Willson AI has become a more regular part of how mechanical engineers and product designers work, though adoption is uneven and the tools still vary in maturity. Early AI models may have failed to account for constraints or produced unrealistic geometries, but recent advances […]
USP Class VI Plastics: Materials and Manufacturing Guide for Medical Devices
When a medical device program reaches the material selection stage, one of the first questions a supplier qualification team asks is whether the plastic components meet USP Class VI requirements. It is a familiar callout on drawings, RFQs, and supplier qualification forms across medical device, pharmaceutical packaging, and bioprocessing programs. Most molders and resin suppliers […]
MISUMI Americas Expands Mexico Operations with New 45,000 Square Foot Monterrey Facility
New site more than quadruples prior space and adds in-house manufacturing and fulfillment of mechanical assemblies Monterrey, Mexico and Oakland, CA— November 12, 2026 – MISUMI Americas today announced the grand opening of its new 45,000 square feet facility in Monterrey, Mexico. More than quadrupling the size of its previous location, the facility expands MISUMI […]
Choosing the Right Stainless Steel for Your Manufacturing Program
Picture a food mixing agitator that runs fine for a year. Then salty product and the daily sanitizing cycle find the crevice where a paddle meets the hub, and pitting starts under a surface that still looks clean. The drawing said “stainless.” It just didn’t say which one. Stainless steel is a family of alloys […]
Machine Design Guide: Designing Custom Parts Around Standard Components
Great machine design engineers need more than just a strong technical base. They must also know how to select the best components for a given project. That includes which parts to buy from a catalog and which ones to custom design and manufacture. Standard and configurable components like bearings, gears, linear rails, and fasteners are […]
Metal Material Selection Guide: Choosing the Right Alloy for CNC Machining and Sheet Metal Parts
Picking a metal for a custom part is one of the most critical decisions you’ll make in the design process. Get it right, and your part performs as expected, machines or forms cleanly, and ships on time. Get it wrong, and you’re looking at cracked bends, corroded hardware, blown budgets, or a part that’s simply […]
Reducing Machine Downtime: Replacement Part Design for Serviceability and Maintainability
Machine downtime comes at an exceptional cost for manufacturers. Siemens’ True Cost of Downtime study reported the cost of a lost production hour at $36,000 in fast-moving consumer goods (FMCG) and up to $2.3 million in automotive manufacturing. Whether a stop is planned or not, a slow repair makes it longer, and every added hour […]
Thin Metal Parts: Design, Materials, and Manufacturing Guide
Thin metal parts are components with low material thickness relative to their geometry, typically below 1–3 mm. At these thicknesses, manufacturing constraints such as warping, stress, and handling become dominant design factors, affecting manufacturability and performance. Thin metal parts are used across a wide range of industries, offering advantages in weight reduction, material efficiency, and […]
Food and Beverage Equipment Manufacturing: Materials, Finishes, and Design Requirements
Food and beverage equipment needs to perform reliably while meeting strict requirements for cleanliness, corrosion resistance, and food-contact safety. A machinery component that corrodes during a clean-in-place (CIP) cycle, traps residue in a machined pocket, or uses an unsuitable polymer can introduce contamination risks, shorten equipment life, and create costly compliance problems. Equipment that produces […]
Heat Treatment for Steel and Aluminum: An Engineer’s Guide
A precision shaft can be machined perfectly, inspected within tolerance, sent for heat treatment, and come back unusable. The shaft may bow, or a bearing journal may lose roundness or move outside tolerance. Reverse the order and a different problem appears. Machining after hardening can increase cycle time, cost, and tool wear or breakage. In […]
