Latest articles
Low-Pressure Die Casting (LPDC): Process, Benefits, and Design Guide
Low-pressure die casting (LPDC) is a permanent-mold process frequently used for casting high-quality aluminum products. It occupies a middle ground between gravity-fed and high-pressure die casting in terms of tooling cost, process speed, and mechanical and metallurgical quality.  What Is Low-Pressure Die Casting? Low-pressure die casting is a casting process that uses permanent molds (dies) […]
FictivMade Part 8: Final Part Unboxing & Testing
The boxes landed at Fictiv HQ, and the payoff was real. After months of designing, prototyping, and manufacturing, the final production run of our multi-tool phone stand is officially in our hands.  If you’ve been following the journey from a simple CAD file to a physical, multi-material product, seeing a table piled high with production-ready […]
Large Part Injection Molding: Engineering Design & Sourcing Guide
Large-component injection molding demands more than just a bigger machine. Once a molding exceeds typical machine footprints, every process parameter becomes more sensitive: clamping force, shot size, flow length, cooling rate, shrinkage, gating, and supplier capacity all require careful attention and specific strategies. The risks also scale proportionately. Minor DFM errors on a small part […]
New
Fictiv Receives 2026 SupplyTech Breakthrough Award For Sourcing Solution of the Year
Annual Awards Program Recognizes Innovation in the Global Supply Chain Technology and Logistics Industry SAN FRANCISCO, June 11, 2026 – Fictiv, a global manufacturing and supply chain company, has been named Sourcing Solution of the Year by SupplyTech Breakthrough in their 5th annual SupplyTech Breakthrough Awards — recognizing standout technology companies across the global supply chain and […]
Industrial Automation and Machinery MRO Strategy Guide
Unplanned downtime is the most expensive line item on a manufacturing plant’s balance sheet, with costs averaging $260,000 per hour in 2026.1 Emergency repairs cost 3–10 times as much as planned maintenance due to supply chain disruptions, overtime labor, and expedited shipping.2 Across the automotive, semiconductor, consumer products, and heavy industrial sectors, a stalled production […]
JIT vs. Safety Stock: Balancing Cash Flow and Uptime in MRO Inventory Strategy
In an idealized manufacturing ecosystem, operations would carry zero inventory liabilities. Vital industrial automation components would materialize on the factory floor the exact millisecond a running asset failed, entirely eliminating storage overhead while sustaining peak Overall Equipment Effectiveness (OEE). In reality, relying on an unmitigated Just-in-Time (JIT) model for high-velocity production lines is a massive […]
How to Survive the Rush to Market for Humanoid Robotics: A Sourcing Strategy & Production Scaling Guide
The global race for physical AI dominance has officially moved from long-term research into a capital-intensive commercial sprint. The explosive growth of humanoid robotics manufacturing mirrors a classic hardware gold rush: venture capital is flooding the space, and the timeline to field a functional unit has compressed dramatically. The pressure on engineering and operations teams […]
MISUMI Americas Unveils AI-Powered Supply Chain Platform to Redefine Mechanical Sourcing
Global manufacturing leader helps companies navigate tariff volatility, accelerate product launches, and scale from standard components to complex production assemblies through one trusted partner San Francisco, Calif. – June 1, 2026 – MISUMI Americas, a specification-driven sourcing partner for mechanical components and assemblies, today announced the expansion of its AI-powered supply chain platform designed to […]
Reverse Engineering for Industrial MRO Parts
How to Restore Production Continuity for Legacy Systems Facing Component Obsolescence Industrial equipment doesn’t fail on schedule. A damaged bracket, worn housing, obsolete fixture, or discontinued machine component can bring production to a halt—especially when replacement parts are no longer available from the original manufacturer. For companies operating aging industrial equipment, robotics systems, aerospace hardware, […]
3-Axis CNC Machining Guide: Capabilities, Limitations, and Use Cases
3-axis CNC machining is a manufacturing process in which cutting tools move along three linear axes (X, Y, and Z) to remove material from a workpiece. It’s the most common type of CNC machining, ideal for producing simple to moderately complex parts with flat surfaces, pockets, and basic contours. 3-axis CNC machining is a powerful, […]
