Content type
Role
Topic
Manufacturing Processes
Latest articles
Reducing Machine Downtime: Replacement Part Design for Serviceability and Maintainability
Machine downtime comes at an exceptional cost for manufacturers. Siemens’ True Cost of Downtime study reported the cost of a lost production hour at $36,000 in fast-moving consumer goods (FMCG) and up to $2.3 million in automotive manufacturing. Whether a stop is planned or not, a slow repair makes it longer, and every added hour […]
Thin Metal Parts: Design, Materials, and Manufacturing Guide
Thin metal parts are components with low material thickness relative to their geometry, typically below 1–3 mm. At these thicknesses, manufacturing constraints such as warping, stress, and handling become dominant design factors, affecting manufacturability and performance. Thin metal parts are used across a wide range of industries, offering advantages in weight reduction, material efficiency, and […]
Food and Beverage Equipment Manufacturing: Materials, Finishes, and Design Requirements
Food and beverage equipment needs to perform reliably while meeting strict requirements for cleanliness, corrosion resistance, and food-contact safety. A machinery component that corrodes during a clean-in-place (CIP) cycle, traps residue in a machined pocket, or uses an unsuitable polymer can introduce contamination risks, shorten equipment life, and create costly compliance problems. Equipment that produces […]
Heat Treatment for Steel and Aluminum: An Engineer’s Guide
A precision shaft can be machined perfectly, inspected within tolerance, sent for heat treatment, and come back unusable. The shaft may bow, or a bearing journal may lose roundness or move outside tolerance. Reverse the order and a different problem appears. Machining after hardening can increase cycle time, cost, and tool wear or breakage. In […]
Smart Manufacturing and What It Means for Hardware Teams
Manufacturers have been automating production for decades. What changed in the last ten years is the layer of intelligence on top of that automation. Smart manufacturing describes production environments where machines, sensors, software systems, and supply chains are connected well enough to generate, share, and act on data in real time. Smart manufacturing is the […]
Custom End Effectors and EOAT: Design and Manufacturing Guide
In robotic automation, the end effector, or End of Arm Tooling (EOAT), is where the digital instructions of the controller meet the physical realities of the workpiece. These terms refer to the specialized hardware mounted to a robot flange that interacts with parts, tools, or the surrounding cell environment. The terms are interchangeable in practice […]
MISUMI Launches Imprint Foundation with $2 Million to Invest in the Next Generation of Builders
First corporate foundation in MISUMI Group’s history opens co-investment to global supplier network Oakland, CA — October 21, 2026 — MISUMI Americas today announced the launch of the MISUMI Imprint Foundation, a new philanthropic institution advancing engineering education, applied design and robotics programs, and industry–academia partnerships across the United States. The Foundation launched with a […]
How to Evaluate a Manufacturing Partner: 8 Criteria That Separate Great from Good
Engineering teams sourcing custom-manufactured components don’t always begin with dedicated production lines or long-term supply agreements. They are moving from NPI through validation, bridge production, and production ramp, where engineering changes remain frequent, and supplier responsiveness is often more valuable than installed capacity. A manufacturing partner, unlike a transactional contract manufacturer, contributes engineering, quality, and […]
Scientific Molding: How It Works and Why It Matters When Qualifying an Injection Molding Supplier
Dimensional drift and defects are the failure modes manufacturing engineers work hardest to minimize in injection molding. Initial sample parts measure accurately, the pilot run looks clean, and tooling is signed off for production. Months later, parts drift out of tolerance, or flash, sink marks, and short shots start appearing. Worse still is discovering that […]
Anisotropic vs. Isotropic Materials: What Engineers Need to Know
Here’s a common mistake: an engineer designs a structural bracket using FDM 3D printing, runs FEA with the tensile strength from the material datasheet, and predicts a comfortable factor of safety. The printed part fails at a fraction of the predicted load. The material and analysis were correct, but the FEA assumed isotropic material properties […]
