Latest articles
New
Fictiv Named One of Fast Company’s 2026 Best Workplaces for Innovators
Fictiv recognized in the Industrial and Manufacturing category for fostering a culture of innovation Oakland, Calif. – September 8, 2026 – Fictiv, a global manufacturing and supply chain company and a division of MISUMI Americas, today announced it has been named a winner in the Industrial and Manufacturing category of Fast Company’s 2026 Best Workplaces […]
Food-Grade 3D Printing and Manufacturing: How to Choose the Right Process and Material
When a customer came to Fictiv needing 3D-printed components for a shrimp sorting machine, their first instinct was to quote nylon (PA) parts with Multi Jet Fusion (MJF). MJF produces strong, accurate nylon parts quickly and at a reasonable cost, making it a common solution for functional production components. The problem is that MJF produces […]
Sheet Metal Material Selection for Aerospace Applications
Choosing sheet metal for manufacture in aerospace isn’t just a matter of selecting the strongest or lightest alloy. For instance, a stronger material that suits machined components may crack during bending, while one that forms easily may lack the fatigue strength for vibration-loaded structures. An apparently suitable alloy may fail in salt spray, elevated temperatures, […]
Prototyping with Casting: Die, Investment, and Gravity Mold Processes
Most prototyping conversations center on CNC machining and 3D printing, and for good reason: both provide parts fast, which is a real advantage for early design work. Once a metal component is headed toward production casting, however, these prototyping methods don’t fully represent the manufacturing conditions and final product. Using the same process for prototypes […]
Request a quote for a single CNC-machined part, then request one for 50 of the same part. The per-unit price will look different—often as much as 70% lower at the higher quantity. The total spend goes up, but the cost per part drops sharply.  This happens across every custom manufacturing process—CNC machining, 3D printing, sheet […]
Custom Manufacturing for Medical Devices: Sourcing, Standards, and Design Considerations
Medical devices are manufactured using the same processes as other products, including CNC machining, injection molding, sheet metal fabrication, casting, and additive manufacturing. The difference lies in the expectations placed on quality systems, documentation, traceability, and process control. Successful sourcing depends on more than price and lead time. It requires suppliers capable of consistently producing […]
What Is Physical AI? A Practical Guide for Engineers and Hardware Teams
Artificial intelligence has been reshaping software for years. But a distinct category—one that matters far more to mechanical engineers and hardware companies—has quietly matured to the point where it’s changing how physical products are designed, manufactured, and operated. Physical AI is the category of artificial intelligence that must operate within the constraints of the physical […]
Pilot Production: How to Plan and Run a Manufacturing Pilot Before Mass Production
The gap between a qualified prototype and a production-ready process is larger than most programs anticipate. A prototype part can pass DVT with flying colors, assemble cleanly at the bench, and clear all functional requirements. Yet it can still generate a yield disaster when tooling runs at production cycle time—when operators follow a work instruction […]
