thumbnail of Sunny Sahota
Fabricate, Processes & Materials
Options for 3D Printing Clear Parts
When it comes to 3D printing clear parts, it’s important to understand the clarity options available to you. Depending on your design requirements, the clarity level can play an integral role in your design review.
Here are 3 options for 3D printing clear parts to help you make the best material choice for your part. To learn more, check out our Capabilities Guide.
Option 1: VeroClear Unfinished
transparent 3d printed part
Unfinished VeroClear material is more frosty than it is transparent. Its best use is for parts that require some translucency, but not optical clarity.
transparent 3D printed part side view
  • Price: Low
  • Technology: PolyJet  (0.016mm layer resolution)
  • Lead Time: 1 day with Rush Production
Option 2: VeroClear Finished
transparent 3D printed part, finished
You can achieve more optical clarity with VeroClear material by finishing it.
To do this, we hand-sand the surface to remove build lines and then finish the surface with a 2-part polyurethane clear coat.
A finished VeroClear part is great for designs that require clarity for functional purposes (e.g., reading a sensor or checking internal component positioning).
transparent 3D printed part, finished, side view
  • Technology: Polyjet (0.016mm layer resolution)
  • Lead Time: 2 day turnaround with Rush Production
Option 3: Acura 60
acura 60 3d printed part
Acura 60 provides the best visual clarity for parts. This material is best suited to mimic glass aesthetically and is great choice when creating packaging or housings that require optimal clarity.
acura 60 3d printed part, side view
  • Technology: SLS (0.06mm layer resolution)
  • Lead Time: 3 day turnaround with Rush Production
clear 3d printed parts, side viewclear 3d printed parts
Last page
How to 3D Print Light Pipes
The advent of 3D-printable transparent materials has opened doors to new possibilities with rapid prototyping for optical applications.
Up Next
Recommended Wall Thickness for 3D Printing
One of the most important considerations when designing parts for 3D printing is the wall thickness.
