Latest articles
What Is Physical AI? A Practical Guide for Engineers and Hardware Teams
Artificial intelligence has been reshaping software for years. But a distinct category—one that matters far more to mechanical engineers and hardware companies—has quietly matured to the point where it’s changing how physical products are designed, manufactured, and operated. Physical AI is the category of artificial intelligence that must operate within the constraints of the physical […]
Pilot Production: How to Plan and Run a Manufacturing Pilot Before Mass Production
The gap between a qualified prototype and a production-ready process is larger than most programs anticipate. A prototype part can pass DVT with flying colors, assemble cleanly at the bench, and clear all functional requirements. Yet it can still generate a yield disaster when tooling runs at production cycle time—when operators follow a work instruction […]
Certificate of Conformance: What It Is, What It Must Include, and How to Use It
A certificate of conformance (CoC) shows up with a parts shipment, and most engineers glance at it, file it away, and move on. That works fine until it doesn’t—if a quality issue traces back to a lot with no traceability, or an auditor asks for evidence that parts were built to the drawing specs and […]
The MRO Obsolescence Mismatch: Why Equipment Outlasts Its Parts and What to Do About It
Industrial equipment is built for longevity, but the components that keep it running are not always built to last. Many production systems operate reliably for 20–30 years, while the mechanical parts, control systems, and electronic components they depend on can become difficult or impossible to source before the equipment wears out. The gap between a […]
The manufacturing process you select impacts part cost, lead time, achievable tolerances, material options, and how easily you can iterate your design. The wrong choice doesn’t just affect the prototype; it can also lock in cost and quality constraints that compound through the entire product development life cycle. Making this decision requires balancing competing technical […]
U.S. Tariff Updates 2025–2026: Latest Changes for Importers & Manufacturers
An ongoing log of major tariff changes and trade policy developments.
Artificial Intelligence is no longer on the horizon for mechanical engineers—it’s already on our desktops, inside our CAD tools, and embedded in robotics on the factory floor. When I started working as a mechanical engineer 15 years ago, I didn’t think much about AI someday reshaping my job. Now the question has shifted from will […]
How to Evaluate a Manufacturing Partner: 8 Criteria That Separate Great from Good
Engineering teams sourcing custom-manufactured components don’t always begin with dedicated production lines or long-term supply agreements. They are moving from NPI through validation, bridge production, and production ramp, where engineering changes remain frequent, and supplier responsiveness is often more valuable than installed capacity. A manufacturing partner, unlike a transactional contract manufacturer, contributes engineering, quality, and […]
MISUMI Americas data highlights record output, a factory construction boom, and $2.42 trillion in foreign investment while backing bipartisan H.R. 9097 to help close a 3.8 million skilled-worker gap through advanced manufacturing training  San Francisco, Calif. – July 21, 2026 – MISUMI Americas, a specification-driven sourcing partner for mechanical components and assemblies, today announced The […]
Injection Molding Cycle Time: What Drives It and How to Reduce It
At scale, cycle time is one of the most direct levers on injection molding costs. It affects both cost per part and maximum throughput, so any design or tooling decision that changes cycle time also changes piece price—at every production volume. For this reason, design engineers and manufacturing or tooling engineers must strike a balance […]
