Latest articles
Manufacturing Continuity and Reducing Risk During Production Scale-Up
Bringing a hardware product from concept to full-scale production is one of the most difficult transitions in manufacturing. What works during prototyping often breaks down during production transition, forcing engineering and procurement teams to switch suppliers, rebuild workflows, and requalify manufacturing processes just as launch timelines become more critical. For many companies, the transition from […]
Semiconductor Equipment Manufacturing for Precision Hardware Systems
Building semiconductor systems is a massive engineering challenge. While many people’s first thought when they hear “semiconductor” may be tiny circuits on a chip, none of those chips could be made without the physical hardware that fabricates them—from robots, inspection machines, and fixtures to custom parts and enclosures. In this article, we’ll explain the best […]
Custom vs. Configurable Components: How Engineers Choose the Right Sourcing Strategy
Choosing between custom and configurable components affects product cost, development speed, manufacturability, and scalability. Configurable components offer fast sourcing and low upfront investment, while custom parts enable optimized performance, integration, and differentiation. Whether you’re planning a new product or optimizing an existing bill of materials, this article explains when to use each approach, how to […]
Scaling CNC to Casting Guide
How to Transition from CNC Machining to Casting for Production Scale Identifying the Right Parts for Casting CNC vs. Casting: Fundamental Differences Casting Process Selection (DFM) Design Adjustments for Transitioning from CNC to Casting Casting Design for Manufacturability (DFM) Considerations Materials & Performance Considerations Hybrid Strategy: Casting + CNC Finishing Simulation & Validation Tooling & […]
Prototyping Cost: What Drives Pricing Across Manufacturing Processes
Prototype costs can range anywhere from under $50 for simple 3D printed parts to $10,000 or more for injection molded prototypes with tooling. The final cost depends on the manufacturing process, material selection, part complexity, tolerances, quantity, and lead time requirements. This makes it difficult to estimate costs upfront without a clear understanding of what’s […]
Gravity Casting (Permanent Mold Casting): Process, Benefits, and When to Use It
Gravity casting, commonly referred to as permanent mold casting, creates parts by filling reusable molds with gravity-fed molten metal. This process sits in a middle ground between sand casting and die casting in terms of tooling cost, surface finish, dimensional repeatability, and production efficiency. It delivers better quality parts than sand casting without the volume […]
Metal Casting Defects: Types, Causes, and How to Prevent Them
Casting enables the efficient production of complex metal parts, but it also introduces a distinct set of quality challenges. Unlike machined parts, cast components are formed by the flow and solidification of molten metal—meaning defects can appear as a result of fluid dynamics, heat transfer, and material behavior. Understanding casting defects is critical for engineers […]
MRO Automation: How Smart Inventory Systems Are Transforming Manufacturing Supply Chains
Walk through almost any modern factory, and you may find a vending machine stocked not with snacks, but with fasteners, cutting tools, gloves, and other essential supplies. At first glance, these machines might seem like a convenience upgrade. But in reality, they are a sign of something bigger: a fundamental shift in how manufacturers source, […]
Data Center Infrastructure Design: Custom Manufacturing and Off-the-Shelf Components for AI and Cloud Hardware
As demand for AI data centers, hyperscale data center deployments, and high-performance computing (HPC) hardware continues to rise, engineering teams are rethinking how to design and build modern data center infrastructure. From GPU cluster infrastructure powering AI training and inference to enterprise data storage systems supporting cloud applications, today’s facilities must balance performance, thermal efficiency, […]
Stage Gate Product Development: A Guide to Process Models and Best Practices
How modern hardware teams build and formalize the processes behind complex programs Stage gate product development is a structured approach that breaks hardware development into defined stages, each separated by decision “gates” where teams review design progress, trade-offs, test results, and risks before moving forward. This framework is widely used in engineering organizations to manage […]
