Latest articles
MRO Automation: How Smart Inventory Systems Are Transforming Manufacturing Supply Chains
Walk through almost any modern factory, and you may find a vending machine stocked not with snacks, but with fasteners, cutting tools, gloves, and other essential supplies. At first glance, these machines might seem like a convenience upgrade. But in reality, they are a sign of something bigger: a fundamental shift in how manufacturers source, […]
Data Center Infrastructure Design: Custom Manufacturing and Off-the-Shelf Components for AI and Cloud Hardware
As demand for AI data centers, hyperscale data center deployments, and high-performance computing (HPC) hardware continues to rise, engineering teams are rethinking how to design and build modern data center infrastructure. From GPU cluster infrastructure powering AI training and inference to enterprise data storage systems supporting cloud applications, today’s facilities must balance performance, thermal efficiency, […]
Stage Gate Product Development: A Guide to Process Models and Best Practices
How modern hardware teams build and formalize the processes behind complex programs Stage gate product development is a structured approach that breaks hardware development into defined stages, each separated by decision “gates” where teams review design progress, trade-offs, test results, and risks before moving forward. This framework is widely used in engineering organizations to manage […]
Cleanroom Manufacturing: ISO Standards, Applications, and Design Guidelines
Cleanroom manufacturing is the production of components in a controlled environment where airborne particles, temperature, humidity, and contamination are strictly regulated according to ISO 14644 standards. Manufacturing in a cleanroom is essential when even microscopic contamination can cause product failure. Cleanrooms allow manufacturing processes like injection molding and CNC machining to be carried out under […]
Prototyping Lead Time: Process Timelines and How to Reduce Delays
Prototyping lead time is often framed as a simple question: “How long will it take to get my part?” In reality, the answer is rarely determined by machine time alone. A prototype expected in days can easily take weeks—not because of production constraints, but because of delays in quoting, design iteration, manufacturability feedback, and supplier […]
Aerospace Materials and Finishes: Component Design for Spacecraft and Satellites
Engineering for Vacuum, Thermal Extremes, and Reliability Aerospace materials and finishes for spacecraft must be selected to withstand vacuum, radiation, thermal cycling, and outgassing. These conditions introduce failure modes such as cold welding, material degradation, and contamination of sensitive components, requiring material and surface finish selection to be evaluated together to ensure reliable performance in […]
What are MRO Parts? Definition, Examples, and Sourcing Strategies
MRO (maintenance, repair, and operations) parts are the replacement components, spare parts, and consumables used to keep manufacturing equipment and facilities running. While they are not part of the final product, MRO parts directly impact uptime, maintenance efficiency, and overall production reliability. Effective MRO sourcing ensures that critical components are available when needed—reducing downtime, controlling […]
Building the World They Want to Live In
Across clean energy, smart buildings, and the skies above our cities, a generation of innovators is turning ambition into hardware, and hardware into a livable future. This Earth Day, we’re celebrating nine of them. Lunar Energy The Lunar System does something deceptively simple. It captures solar energy during the day, stores it in a home […]
Simulation vs Reality in Hardware Development: Prototyping, Validation, and Iteration
Product engineering teams rely heavily on simulation tools to predict how a product will behave before it’s ever built. These tools make it possible to quickly explore design ideas and catch potential issues before they arise. Even the most advanced simulation, though, cannot perfectly predict real-world behavior—which is why simulation validation and structured prototyping are […]
CNC vs Die Casting Qualification Scorecard
Quick Evaluation Tool for Process Selection Compare die casting and CNC machining to determine the best process for your prototyping or production requirements. CNC vs Die Casting Scorecard Score each category from 0–2 based on your part requirements. Category 0 (CNC) 1 (Neutral) 2 (Casting) Your Score Production Volume <1,000 1,000–5,000 >5,000 012 Target Lead […]
